how far can i oc a 2600k on a power watercooling setup?
450 11
Hey guys hows it going?i was wondering if buying a 2600k and a Asus maximums IV Z67 and buying a danger den radiator box and 3 360 radiators and a powerful pump would be a good idea?how high would i be able to clock the 2600k.this is just to get a idea.thanks for any help
1 - 12 of 12 Posts
Please take a look at the 'Sandy Stable Club', link is on my sig. I just added a couple new things to the spreadsheet that I think may help you out, however, just to remind you, all cpu's are different, so the ones that you see on the spreadsheet may not overclock similar to yours, therefore temps will also be different, on that note ambient temps are also very important.
Hope that helps
Waiting on New Hardware
5 GHz should be very easy if your chip doesn't have some upper limit that some chips do.
anything higher than that is rare but possible if ur lucky.
1 - 12 of 12 Posts
