1 - 15 of 15 Posts
well guys have got this far. but with Ht now above 1000 how much more can i risk. The agp/pci is locked the memory is at 5:2 ratio(timmings tight set to 1T)<br><br><br><img alt="" src="http://i126.photobucket.com/albums/p99/dksinden/snap8.png" style="border:0px solid;"><br><br><br><img alt="" src="http://i126.photobucket.com/albums/p99/dksinden/snap9.png" style="border:0px solid;">
Retired
Im confused as to what you are trying to do here. Are you trying to get the HT as high as possible, if so, just keep upping the FSB until you start seeing instability. That being said, your processor is actually running at a slower speed than it is rated at stock because your multiplier is set at 5. It should be set at 10 I think. Anyways, what are you trying to achieve here?
currently trying to find max fsb without blowing things up, but ht is my concern as ive read many faqs about not taking above 1000
Up your multipliyer to 10/9.5 or lower yout HTT multiplyier to 3 and up the FSB.
Retired
<div>Originally Posted by <strong>dksinden</strong></div>
<div style="font-style:italic;">currently trying to find max fsb without blowing things up, but ht is my concern as ive read many faqs about not taking above 1000</div>
</td>
</tr></table></div>
Ahh, ok, just lower your HTT multiplier, there should be a setting in your bios that will allow you to do this. The values you will be able to chose from are 1-5. Just lower that as low as possible and keeping upping the FSB.<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Yea hes testing how far he can take his mobo. lol thats like step one in the oc faq.
I'm rock solid stable at 1100mhz, I've seen mine go as high as 1.3ghz, but I would not run it that high for long. I think your best bet would to try to keep it between 800-1100.<br><br><img alt="" src="http://i14.tinypic.com/4crwt9c.jpg" style="border:0px solid;">
Yeah in BIOS, the HHT rate or something. Watch for an option that is deafaultly set to 4/5.
Might be set to auto.
Discussion Starter #11
Right think ive found it, set out a bit different in my bios<br><br>
200<br>
400<br>
600<br>
800<br>
1000<br><br>
so setting it at 600 will do the job or go lower
<tr>
<div>
</div>
<div style="font-style:italic">so setting it at 600 will do the job or go lower</div>
</td>
</tr>
</table>
</div>600 will do the job for now. <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
your fsb should go really high, mine caps at 400? and i have had it there.
Discussion Starter #14
Work in progress, just keeping you guys up todate.<br />
<br />
<br />
<br />
<img src="http://i126.photobucket.com/albums/p99/dksinden/newoc.png" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
are you still trying to get highest fsb for your motherboard?
1 - 15 of 15 Posts
