1 - 8 of 8 Posts
i own a asus p5gl-mx mobo and i want to know if theres anyone who can go far with the same mobo..
can the FSB really go up to 240MHz as it says in the BIOS?
thanks..
Originally Posted by pauldovi
There is only one way to find out how high it can go! OC it.
well..
i did..
but i can only get 3.48GHz from 3.20?
if i increase the FSB more than 217MHz it wont boot up..
my RAM timings is 3-3-3-8..
what is your ram? i know it says ddr, but what speeds? that could very well be whats keeping you from going higher. your cpu should do 4ghz easy on air, with a big typhoon though.
thanks..
I own the same mobo and went upto 240MHz. The key to getting there is when You arein Jumperfree settings, under the DRAM Frequency select the low frequrency i.e. from the 2 freq listed which have to be 3xx and other 4xx some thing. Select the one which is lower. Then increase the CPU freqancy restart to see if it works. I was having the same problem as you
. I am currently running stock cooling so havent check if the OS is stable too. I have 3.4 Ghz which I OCed to 4.03
but temps were very high like 65 to 67 celcius so didnt botherwd to try running OS. Will confirm it soon when I get a cooling solution.
Originally Posted by x2s3w4 View Post
How long did it take you to find this 2 1/2 year old post?
LOL.
Sorry for such a late reply but its not my fault you can see my registration date to verify it. I had always been hearing about overclocking but never tried it because of all the risks involved
. Also when I bought my new system back in 2005 it was quite fast
compared to standards of those days so never needed overclocking. Recently I had been having issues in upgrading my system and since I could'nt :swearing::swearing::swearing: I thought of trying to overclock :rolleyes. So here I am
P.S. I think minusthirteen had already found out the solution or had already upgradeded but I wrote just to help out someone whos looking for the same answer
1 - 8 of 8 Posts
