How high can i oc this tri core
254 Views 3 Replies 4 Participants Last post by  amder
its the one in my sig. its a 2.1ghz which is pretty low i want to know the highest i can get with it. its not a black editon
1 - 4 of 4 Posts
if you use ln2, you'd probably hit 4.0ghz with that
here's some on air
http://www.hwbot.org/quickSearch.do?hardwareId=CPU_1627
2.7 GHz at best.
That is a >50 MHz OC on the ref clock, which is a bit higher than the average upper limit people run into. Personally though, I can't get over 240 MHz.
Ive gotten my 8650 X3 2.3Ghz to 2.7Ghz running stable as of now. temps are 30c idle max ive seen was like 45C with my cooler.
1 - 4 of 4 Posts
