1 - 6 of 6 Posts
I deleted the Linux partion but when I just did a reboot GRUB loaded up, How do I uninstall GRUB?
OVERCLOCK IT OR DIE
Get a Windows 98 or later boot disk and start up with that. Once you get to the command prompt type in <b>FDISK /mbr</b><br><br>
Here's where you can get some: <a href="http://www.bootdisk.com" target="_blank">www.bootdisk.com</a>
Reactions: rfarris
Boot into Windows, and go<br><br>
Start > Run > cmd<br><br>
At the command prompt, type "fixmbr" (without quotes) and upon reboot there should be no more bootloader.
Reactions: rfarris
Discussion Starter #4
Just rebooted, GRUB loaded, but didn’t do anything, put in that Norton ghost recovery cd had it restore the master boot record, and it works fine now.<br />
<br />
Would fixmbr do the same thing? Also is GRUB completely gone now?
Throw in your XP cd. Get to the recovery console (i assume you know how) and type:<br />
<br />
fixmbr<br />
<br />
and say yes to whatever it asks<br />
<br />
and then<br />
<br />
fixboot<br />
<br />
and say yes to whatever that one says
Reactions: rfarris
OVERCLOCK IT OR DIE
Yeah restoring the master boot record is what fixmbr does.
1 - 6 of 6 Posts
