How important are drivers for sound quality?
428 Views 4 Replies 4 Participants Last post by  TwoCables
I have Z-5500 speakers with an X-Fi Titanium sound card. I've had horrible experiences trying to install drivers with this card, and after hours and hours of trying to fix it I finally managed to get the drivers from the disk installed. They're from January, but there are some July drivers for the X-Fi available. I'm not having any technical problems, but will sound quality improve? If not, to hell with it, I'm not messing with it again
Also, what about "High Definition Audio Device"? I don't know what that is, but apparently I have 2006 Microsoft drivers for it. According to a program I use called "Driver Detective", there are some newer drivers for this "High Definition Audio Device". The new drivers for it are, it says, from "Realtek" and are dated at September 2009. What are these drivers? And will they improve sound quality?
Thanks for the help.
1 - 5 of 5 Posts
The "High Definition Audio Device" is the onboard audio. This must be disabled in the BIOS when using a sound card. This may have been why you were having difficulty getting the X-Fi drivers to install.
So, disable it. And if you still have any Realtek drivers installed, then uninstall them immediately.
High definition audio device is your motherboards onboard sound, you should disable it in BIOS but it's not too important if it isn't causing conflicts - it will be using resources though.
I'd also leave the drivers as they are for the X-Fi, I've had similar driver installation issues in the past and it's not worth it IMO - I don't think there is any difference in SQ anyway.
If it's not broke, don't fix it
One of the reasons you probably have problems installing your X-Fi drivers is because your haven't disabled your onboard audio yet. That High Definition Audio Device is your integrated soundcard. Disable it in your BIOS.
And generally, drivers will not make sound quality better - but better drivers will be more stable and have less problems. I wouldn't upgrade sound card drivers unless you're actually having problems with your current drivers.
Of course, there are always Daniel_K's drivers which do improve the quality a tiny bit.
1 - 5 of 5 Posts
