1 - 14 of 14 Posts
Yes it will unlock cores. (Read here)
From what I've seen, it's a solid board as far as component selection goes.
No words on Overclocking yet, but Biostar's T-Series boards for AMD & Intel have been solid choices. I would go with it.
thanks for the help +rep
No problem man.
That board seems to be solid:
Looks
Components
BIOS Options (aka, Core Unlocking, necessary voltages)
It's all there. So I've got hopes for it.
You should post a review & such when you get the board. That way more people can see what it's really like.
Discussion Starter · #6 ·
No problem man.
Looks
Components
ya im stuck with a 1 core cpu XD at this time low on funds
http://www.newegg.ca/Product/Product...-698-_-Product
mind you its only for basic uses
not to play BFBC2 maxed out might blow it up XD
Discussion Starter · #8 ·
i would like to get a amd 555 x2 when i get more funds
no OC on the single core could try a unlock and see how that goes may not unlock who knows i think its all up to the chip i think
Sempron 140's are Athlon II x2's with 1 core disabled.
ACC, NVCC, or any of the new Core Unlocking techs will allow you to unlock a core if it's a good one.
Discussion Starter · #12 ·
i see ill let you know how it goes once its built
If you are ordering this board in hopes of unlocking cores, you need to pay attention to which version of the board you get. NewEgg just delivered one to me (by mistake, I had actually ordered a 790gx board.) The features look nice, and was considering keeping it, but found out the following. Versions 5.0 and 5.1 do not support ACC or Biostar's "Bio-Unlocking." You will need version 5.2 in order to unlock/lock cores. See the following link, when you switch from v5.0/v5.1 to v5.2 in the drop down box, the only thing that changes is the AMD OverDrive with ACC feature ability on the 5.2.
http://www.biostar.com.tw/app/en/mb/...t.php?S_ID=474
More on Bio-Unlocking
http://www.biostar.com.tw/app/en/eve...king/index.htm
I do like the board, going to call and see if they have any 5.2's in stock that I can swap this 5.1 for. Looks like I won't be starting on this build until next week.
Discussion Starter · #14 ·
went with it due to the cost and make of the mobo best one i could find for the money
i was just hopeing it could unlock cores
1 - 14 of 14 Posts
