How is this 650watt PSU with sli 260gtx?
868 Views 14 Replies 9 Participants Last post by  Yukss
I made an impulse buy on an MSI open box 260gtx from the egg a few minutes ago.
I also plan on using an i5 and oc'ing to around 3.8ghz-4.0ghz. Since there's no ht it might save some power. Also I'll be using a single Intel ssd which might save some power.
I have this HIGH QUALITY earth watts psu.
http://www.newegg.com/Product/Produc...%20watts%20650
It seems to have enough amps on the 12v rails. I know this power this "power issue" has been blown out of proportion in the past before.
If someone could give me a good answer I would be grateful + rep.
1.) Would I be good for a second 260 gtx?
2.) This is kind of unrelated but my new mobo is p55. Apparently p55 only supports x8/x8 on the pci-e lanes with SLI. In reality would I notice a performance hit? I know I might with say sli 295gtxs, but in this case I'm thinking I'd be just under the bottleneck.
1 - 15 of 15 Posts
Link is broken.
page is unavailable. id say you will be fine. maybe cutting it a little close. but fine.
I think a good 650w PSU is fine for your setup as well
Heres the math:
1 GTX 260 takes 182 watts peak
2 GTX 260 takes 364 watts peak
[email protected] 4.0ghz takes 296 watts load
but i5 uses about 30 less watts.
thats equals to be 620, excluding CD drives, fans and Harddrives
I think to be safe, get a 700 watt or a 750 since you are going to be overclocking it a lot. If you werent I would say a 650 would suffice since a STOCK i5 uses 184 watts at load.
Once you overclock it to around 4.0 ghz the wattage jumps to the high 200's
http://www.newegg.com/Product/Produc...82E16817371015
if this is the one you were talking about.
then yeah, should be just fine.
Yup, that's the one. Thanks guys.
Good luck with your new PSU, i do hope you get yourself at least a 700 since you will be heavily overclocking that i5
take a look at this one:
http://www.newegg.com/Product/Produc...-025-_-Product
Same price for a 750 watt and its the same brand PSU. But with mail and rebate though
I already have this psu sitting at home from my old comp.
i7 takes nearly 300w full load? that doesn't seem right hwmonitor says like 150w..??
edit: hwmonitor must be wrong this beast sucks power - even idling
glad I got the 1250w PSU
you beat me by 50 watts. Thats it, im getting a 1500w PSU!
I tested my gaming rig awhile ago with a wall meter. The system has an OC'd E8600, 4gb RAM, 2 260s, 3 HDDs, and 6 scythe s-flex's.
At the wall the meter peaked at 500w while the system was folding on both GPUs. That is typically a higher load than you will see while gaming, but obviously lower than any i7 runs.
At idle the rig was running between 245-255watts.
1. You should be fine with your PSU.
2. The lower 8x/8x shouldnt hurt you with this setup either. Enjoy the new GPU!
2 kilowatts or you are a baby!
I was checking those out the other day. The only problem is that it requires 2 plugs, so you need 2 different outlets in 2 different zones of the house. That way you dont blow a fuse.
I didnt feel like buying a long extension cord, so I just settled with a quality Corsair 750W unit.
1 - 15 of 15 Posts
