How is this ITX HTPC build.
562 Views 3 Replies 4 Participants Last post by  ounderfla69
I was looking at an HTPC and I think mini-ITX is the way to go. Anyone got any advice on how to save more money on this build?
https://secure.newegg.com/WishList/M...px?ID=12737908
1 - 4 of 4 Posts
Its nice, costs a little much for what you are getting.
But thats a trade in for size.
The only thing I can say is I don't know a whole lot about hat TV card. But good brand/series. So you should be fine their, I just haven't done my homework.
check out www.mini-itx.com , they have a lot of awesome projects on there.
I would suggest instead of the Hauppauge WinTV-HVR-1600, I would get the Hauppauge WinTV-HVR-2250. It has 2 inputs one is for FM and the other is a dual Hybrid tuner which splits the signal into 2 and lets you record 2 different analog or digital show. This feature doesnt work if your using a cable box.
1 - 4 of 4 Posts
