I have been posting on this site for a little bit, and you guys have been a great help. If you could help me on this, it would be great.
How is this for a CPU + GPU loop
Water Block - http://www.frozencpu.com/products/16252/ex-blc-1132/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Nickel_EK-Supremacy_-_Nickel.html?tl=g30c325s842
Rad - 1x http://www.frozencpu.com/products/8522/ex-rad-145/XSPC_RX240_Dual_120mm_Radiator.html?tl=g30c95s160
1x http://www.frozencpu.com/products/4083/ex-rad-84/Black_Ice_GT_Stealth_240_Radiator_-_Black.html?tl=g30c95s160 (the stryker does not support top rads larger than 50mm thick
reservoir - http://www.frozencpu.com/products/6472/ex-res-129/XSPC_Dual_525_Bay_Reservoir_-_Black_-_Ball_Front_BR525DBW.html?tl=g30c97s168#blank
pump - http://www.frozencpu.com/products/2128/ex-pmp-27/Swiftech_MCP655-B_12v_Water_Pump_w_38_Conversion_Kit_317_GPH.html?tl=g30c107s1802
gpu block - http://www.frozencpu.com/products/15577/ex-blc-1081/EK_Radeon_HD_7950_VGA_Liquid_Cooling_Block_-_Acetal_Electroless_Nickel_Plated_EK-FC7950_-_AcetalEN_Nickel.html?tl=g30c309s1626
All w/ 1/2" ID compression fittings, and some white ( for part of cpu loop) and red ( for part of gpu loop) primochill tubing.
btw i know thats a 7950 block, im getting one and giving my 7850 to my brother.
All of this going into the CM Storm Stryker!
