1 - 2 of 2 Posts
I Am Gooble Gobble
will it take for a boinc project i just started to begin showing results on the boinc main stats page?
BOINCStats updates once per day. You will typically start seeing stats on BOINCStats 2-3 days after you started. Free-DC Stats updates more frequently, and it looks like you have put up some points today in PrimeGrid.
Currently your cpids are split. What this means is that you probably had points in a project in the past, and now you have submitted points from a new machine. Typically your cpids will eventually merge, but it can take some time. Here is a link to what your cpid is, and why you have more than one. Why do I have duplicate/split accounts (CPUID / CPID) in the BOINC combined stats?
1 - 2 of 2 Posts
