1 - 18 of 18 Posts
This should be in intel Cooling, but that place has been abondend.
I want to know how many Fans you have in your Intel case:
If you really want you can say how many you have in your AMD system aswell.
The fans include all Case Fans, CPU fans, PSU Fans, GPU Fans and anyother fans you have in your box.
layout should look like this (example only)
Case: 120mm+80mm+80mm
CPU: 80mm+80mm (if you have 2 fans on your CPU)
GPU: 2 Fans (don't need to add size becuase there roughly all the same size)
PSU: 80mm Fan
Other: Dual PCI Fans to cool Graphics, Hardrive Fan and Radiator Fan (if you have water cooling).
You don't actually realise how many fans you have in your computer till you count them like this. Please post your amount of fans...
Here's mine:
I'm waiting on my CPU, but when it gets here i'll have this amount of fans (should be here in 1 to 2 days)...
Case: 120mm+120mm Fans(1 front & 1 back)
CPU: 80mm+80mm+80mm+80mm Fans
GPU: 1 Stock Fan
PSU: 80mm Fan
Other: None
ok...heres mine:
cpu:water
gpu: modded stock and pci vantec spectrum(60x2)
psu: 2 80mm
case: 6 80mm
harddrive: 2x vatntec hardrive cooler w/2x40mm
OTES on mobo 40mm x2
Ram: 2x 40mm
Case: (5) 80mm, (2) 120mm
PSU: (2) 80mm
CPU: (1) 80mm
GPU: (1) 40mm
PCI fan card (2) 80mm
That's my 2.8E folding rig, main rig doesnt have a case.
Case:4 x 80mm
CPU: 0
GPU: 1 Artic NV5
PSU: 2 x 80mm Fan
Discussion Starter · #13 ·
Since i have or will have 4 fans on my heatsink. I was wondering. How effective do you think the extra 3 fans will be on a stock HSF. They'll be piled ontop of eachother, so the air should get faster and faster as it goes through each fan which should mean more air goes thorugh to cool the Heatsink.
Do you think it will make a difference (i'll be checking anyway but i just need some opinions)
1 - 18 of 18 Posts
