I'm looking at a computer completely cooled by water. RAM, Mosfets, Chipset, CPU, Dual GPU (770), as well as 2x240mm rads, and about 7-9 90º fittings, all strung together on 3/8 ID tubing. I want everything overclocked as far as I can get it.
The block list looks something like this:
Koolance 380i
2x EK-FC770 GTX (Copper)
4x Koolance RAM-33
Koolance CHC122
EK M5G Mosfet cooler for a Maximus V Gene
I'm wondering if one 655 is enough, or if I need to switch my choice to a 35X or even the Swiftech MCP35X2.
Also, will this be enough radage, or will I need more? I'm building in a Corsair 350D and suggestions on rads are more than welcome.
Before you tell me the massive number of blocks is overkill, I know, and that's why I'm doing it.
Koolance 380i
4x Koolance RAM-33
Koolance CHC122
