1 - 15 of 15 Posts
I just put up 4 computers(2 intel/2 AMD) and I haven't tested them yet coz I don't have an extra OS lying around...
So I'm looking to buy a W7 Pro or Home, Full Retail.
Now my question is, how many time(s) can I install W7 retail (without activating it) so I can just test out my newly built PC's? Is there a limitation on how many times you can install it?
thanks in advance!
Edit: Also if I decide to activate it, is there anyway that I can deactivate it and activate on a different PC?
w/o activation, you can technically install as many times as you want. You dont even need to put a product key when you install.
As far as i know as many as you please. As it gives you 30 days to activate it then. But the key is only good for one pc though.
yeah and after the key is up you can just call microsoft and ask them for a new key if you have to reinstall or something. i did that when reactivating windows XP back then when the key i had didnt work.
I had LEGIT Dell win 7 pro 64bit cd"s but they wouldn't work ( I couldn't activate them WHATSOEVER)(they came with a Dell laptop from work) and I forgot the name of the software, and badaboom, activated!
Originally Posted by The Master Chief
1 with activating, otherwise it will last 30 days without on as many computers as you want.
I seen what you did........................
There's actually a legal way to extend the trial period to up to one year if you want. It's on an article on AskVG (you guys should check out that website; it's awesome).
Not new to Overclock.net
Originally Posted by roanie25 View Post
would that 30 days expiration will restart if I uninstall the OS?
The only way to really uninstall it is to basically reformat the HDD. But I don't know if this will restart the clock, so to speak.
As long as you don't activate any of them, each computer will have 30 days.
The correct answer is: 120 days.
Use the slmgr /rearm command in administrator mode activated command prompt to renew your activation period for another 30 days. This can be done 3 times for a total of 120 days per fresh installation of windows 7.
http://www.mydigitallife.info/2008/1...7-to-120-days/
Worked for me!
so after 120 days i will be forced to activate it? what if im not connected to the internet?
Then you'll be able to call.
1 - 15 of 15 Posts
