This would be what i would do, id get some cheap extensions and bend those, i wouldn't wanna mess around with the heat shrink right on you psu cables. plus is something happens to your cables like a short or something you wont have to replace the whole cable but just the cheap extension.
I was trying to avoid spending more money. Hell its only money.
Be nice if they made male, female 90 degree PCI adapters.
Im not 100% sure but you could possibly make one of these, i know somewhere on here i saw a link to the connections for them without cables, you could possibly make on yourself.
They should also have the 90degree adapter though it would be a big help for alot of people.
Bend em as much as you want I don't think you can really pinch off a current like you can a water hose...but when you put the top on besure it doesn't push the cables and the connecters down offa the gpu.
Overclock.net
