How Much Better Than Stock?
368 9
I was taking a look at one of these and I was wondering how much of an improvement I would see over stock cooling. Anyone know?
1 - 10 of 10 Posts
Um...that is equivilant of stock cooling. If you really want to "upgrade" from stock cooling, I suggest either the Zalman or Big Typhoon.
You got a good system there I wouldn't waist my time with any thing other than the typhoon, save up for it you won't regret it.
Discussion Starter · #8 ·
Is it worth it to go for that Scythe or should I save a little more cash and go for the Big Typhoon? What kind of temp differences would I see between the two? That Scythe has really good reviews on newegg.
1 - 10 of 10 Posts
