almost 100% positive you wont hit 3ghz overclock with a opt 165 but nothing is impossible... I would say you should aim for 2.6ghz - 2.8ghz being your best possible overclock especially if your just going with Air cooling,,,
its a good proccessor and can most likely run up to 2.6ghz and get you right up there near those FX-60 speeds,,,
the L2 cache for the OEM and the Retail is exactly the same and you should probably do some research with the search feature on others results with the opteron 165,,,
good luck
Originally Posted by Dr_1337 I am leaning towards a dual core opteron for OC later down the line. up to a fx-60 performance, because neweggs oem 165 opteron has 128kb+ 128kb L1 cache. That means if I can get it up to 2.8GHZ(Or 3 ) it will be Identical to a 1300$ CPU ?. Maybe 3ghz is possible... with OCing, tweaking. I not overclock till at least the warranty runs out. What do you think... |
good luck
