Hey guys,
As the title states, I'm trying to decide how much further to try and overclock my 580s. They are currently in a loop with a total of 600mm of rad space (all cooled via push/pull) and never break 45*C at max load. My current clock is:
Core Clock: 920 MHz (Not sure what the shader clock is, scales with core)
Memory Clock 2004 MHz
Voltage: 1100mV or 1.1V
The cards never crash and I never experience artifacts with this overclock. Should I push it further? Also, what program do you guys suggest for stability testing a GPU? I've been using MSI Kombuster.
In addition, I was wondering when I'm going to start seeing the effects of Voltage degradation (not in respect to time, but at what V levels I should start to worry). I've been told Voltage isn't a problem if the temps are fine... but that sounds plain wrong. More pressure means more pressure period.
Let me know what you guys think, also if I should start OCin'g the memory as its still currently stock.
Thanks,
-GA
Thanks,
-GA
