Hello I'm currently doing a build with Corsair AX760 and was wondering if I could safely hook up:
a fan controller (Bitfenix Recon) with 2x 120mm fan and 2x 140mm fan and 2x Hard drive all to one of the 8pin to 4x molex extensions?
I might be just being over cautious but I suppose its better to ask . Or I should give the hard drive its own power?
Reason I ask is that I'm trying to save wires and if they can all work safely on one then thats one less extension to worry about.
Thanks for the help.
