1 - 19 of 19 Posts
Originally Posted by Q9300noob View Post
My psu max is 285 will it still work?
You should be fine if it's a decent enough supply, but why do you have such a weak PSU?
And what is the best grphic card I can get
You can pretty much run anything that doesn't require external power. I think the 9500 GT is the highest Nvidia offers, although the 9600 Green Edition and GT 130 will be out soon
Originally Posted by EGOvoruhk View Post
http://www.nvidia.com/object/geforce_8400_Gs_faq.html
Q: What are the power requirements for the GeForce 8400 GS GPU?
A: GeForce 8400 GS cards have a maximum power draw of 71 watts.
No way a 8400GS will hit 71w though... the TDP on is 40w and probably uses less in the real world...
Thank you, I saw that and was like
Does the grphics card that I stated above need external power?
Definitely not. It gets all the power from the PCIe slot.
1 - 19 of 19 Posts
