1 - 6 of 6 Posts
it's a p55 chipset. i know there are limitations when you crossfire or sli. but i don't want to spend another $400-$500 if there won't be a significant increase from just a single configuration or 1 480. thanks.
Are your games lagging?
Originally Posted by ELmo1989
Sli Limits
Crossfire Limts
http://xdevs.com/eplugins/content/co...php?content.30
Update Sli How to. Need translate.
The GD80 supports SLi out of the box.
In answer to your question; x8/x8 will be fine for it. Getting a P55 board with a bridge chip would also be a waste as the added latency gives you less frames than without.
Edit: Depends on what games you are playing to as whether you would see a noticeable increase in FPS. What games are you currently playing?
1 - 6 of 6 Posts
