I'm just curious how much you guys would spend on something like this:
Corsair Obsidian 800d Case
Corsair 1000 Watt HX Modular Power Supply
Core i7 975 Extreme Edition Processor, Overclocked to 5ghz Stable.
12 GB of Corsair Dominator-GT RAM with Ram Cooler. 2000mhz
EVGA Classified E760 4 Way Sli//xfire Motherboard
4 ATI Radeon 5870s in Quad Fire Configuration.
4 OCZ Vertex Series SSD 250gb in Raid 0.Total of 1GB of Solid State Disk Memory.
1 Samsung Blueray Burner Optical Drive
There is also a FULL watercooling Dual Loop system installed inside this computer:
Feser 360mm TFC Xchanger Radiator Mounted underneath the top of the case.
Black Ice GTX 240mm Radiator Mounted at the base of the case.
Black Ice GTX 140mm Radiator Mounted at the back of the case.
Heatkiller 3.0 1366 CPU Waterblock
EK Full Cover EVGA Classified Waterblock
4x EK Full Cover ATI Radeon 5870 Waterblocks
2x XSPC Dual Reservoirs, both illuminated with green and blue UVs
PrimoChill UV Tubing 1/2" ID
Compression Fittings All Around
It would end up looking something like the following, but with 4x 5870s watercooled installed:
Minus the monitors, mouse, and keyboard:
