I'll try to keep this short, but I would appreciate it if you folk could read it to understand my situation.
After years of owning my i5 2500K and running it at stock, I decided to give it a spin and OC it to 4.5GHz since everyone says it's easy. I do that following this guide (http://www.overclockers.com/forums/showthread.php/693613-Beginners-How-to-set-your-25-6-700K-to-4-5Ghz) , and right now after all the stress tests and everything the CPU is sitting fine at 4.5GHz, 1.35V.
After that I decided to push the volts lower and see how far I can go. I managed to go to 1.34V where all stress tests still passed and where temps are safe, but when I did the same thing at 1.33V and lower only 1 program gave me BSOD - Intel Burn Test (at Maximum).
The following programs are what I use for stress testing and all of them pass at 1.33 or lower voltage except IBT:
- Prime95 v26.6 (Small FFT's and Blend mode, 6h)
- Intel Burn Test (Maximum 10 runs, Very High 10 runs)
- Intel Extreme Tuning Utility (30 min.)
- AIDA64 Extreme (CPU, FPU, Cache) (1-2h)
- Asus RealBench (5 runs)
- Cinebench (5 runs)
- Battlefield 3,4,1 (2h+)
So far I'm at 1.32V and I pass all the tests stated above with the exception on IBT with full RAM usage, and if I actually set custom settings in IBT where my RAM is 90% of available it ALWAYS passes, but never when maximum ram is used. Now the temps get significantly lower when I reduce the voltage's and I'd rather like to keep it that way.
Now I wan't to ask you guys is how safe can it be to stay on an overclock which only fails at 1 stress test program, because the temps from 1.32-1.34V are quite noticeable.
This PC is used only for gaming and not any heavy encoding, folding etc..., so this is the whole point of starting this thread to see if I should bump the VCore up just because I fail on 1 stress test
My PC specs if anyone is curious are:
i5 2500K
CM Hyper 212+
AsRock Z77 Extreme4
2x4GB RAM
GTX 980 Ti
Thanks in forward.
i5 2500K
CM Hyper 212+
AsRock Z77 Extreme4
2x4GB RAM
GTX 980 Ti
Thanks in forward.
