1 - 13 of 13 Posts
I have about $950.
This is how I am planning on spending it, any suggestions would be great!
New Motherboard, I want to replace by poo Intel motherboard:
- ASUS P5WD2-E Premium
http://labs.anandtech.com/alllinks.php?pfilter=4209
$232
New Processor, I want more L2
Intel P4 641 3.2Ghz 2mb L2, 64bit, 65nm
http://labs.anandtech.com/alllinks.php?pfilter=4206
$252
Memory- I am looking for more performance memory with better timings
OCZ Gold 2X512 3-3-3-8 DDR2-533
http://labs.anandtech.com/search.php...331024ELDCGE-K
$90
New GFX, just because this 6800 will bottleneck the new system
http://labs.anandtech.com/alllinks.php?pfilter=3016
$285
Total: $867
Other possible componets:
Another stick of the above RAM
$98
Raptor- Put me in RAID0 on the raptors :)
$155
http://labs.anandtech.com/alllinks.php?pfilter=462
New Case, because mine sucks!
Anyother Ideas, possibly a Maze4 for my videocard...
my suggestion, get a dual core amd
Originally Posted by Lucid
http://labs.anandtech.com/search.php?q=pentium+d+920
pentium d 920 for 10 dollars more
also, how about a psu to pwoer all that ? OCZ 520 ?
I have an Antec SmartPower 2.0 500W... I think that will sufice!
As for the dual core, I am not sure if want to venture in the direction yet. There is no current boost in performance for dual core is there? Will Vista utilize dual core? Plus it is only 2.8Ghz...
Please do not suggest AMD, this is in a Intel forum and I am a Intel guy
LOL-I'm not an amd guy. I have three intels. I'm just saying he could get much better performance from an x2. Yes vista will use dual cores. Future games and apps will be multithreaded and so far, in current apps/games/benchmarks, the performance isn't all that bad compared to single cores. Plus you oc an amd better because of their power consumption/temps. People just need to keep open minds when it comes to numbers. Numbers don't lie, and for the most part, the x2's are faster. Multi-core is the future.
Just wait a year and then you will be able to get a lot of computer for 900. Moore's Law and all that. Besides, then the top-of-the-line technology we have now will be a bit cheaper.
Discussion Starter · #11 ·
Originally Posted by Remonster
The Presler Pentium D 900s overclock VERY easily above 4.2GHz on regular air cooling, may want to consider that.
Several people have said that. I am going to look into it!
I remember when......
Make that another, the 9xx chips are nice, and I have heard of many people getting the 920 (2.8Ghz) to 4Ghz, so it's rather common. Although, I don't know about doing it on air
I'll get water for mine before I try for 4Ghz.
However, if you already plan to buy a Conroe in when it is released, I also recomend to wait. But then, I don't have the money to even consider that, so, if you do, then go for it. But I still haven't seen anything SOLID that the 975 chipset will support Conroe, all I have heard is that a BIOS update is expected......if that doesn't happen, you may be buying a new mobo too.
Considering your plan, I'd buy a x1900xtx and watercool it to tide you over until you get your Conroe. That way, when it's time for your new system, you're taking some killer parts with you. You'd still have a lot of money left over,also. Maybe use it to buy a 21" monitor.
1 - 13 of 13 Posts
