.m2v, is pretty much an svcd
this is just a little confusing, but read it properly and it makes sence.
- DVDAuthorgui is a basic win32 frontend for the DVDAuthor project. It can be downloaded here.
- A nice guide can be found here.
- Start DVDAuthorgui:
- Set the DVD format on PAL or NTSC.
- Press "add title" and add your video stream (m2v) and audio stream (AC3 or mp2).
- Under the file tab select "create iso after authoring".
- Press "author dvd".
- Enter a folder name in which the VIDEO_TS and AUDIO_TS folders will be created.
- The iso file will be created outside the named folder.
- Preview with Daemon tools: select mount image -> open the iso file.
