You will have to use Orca to divide the file in half, and put part of the file on one disk and the other part of the file on another...
Either that or just use WinRAR to compress the file into parts, and put half of the parts on one flash drive, and the other half of the parts on another.
as much as i'd love to do that, its for a friend and shes not going to understand how to deal with it. lol. im trying to make it as simple as possible.
Originally Posted by samster25
just rar it to fit it into two parts on a dvd-5 there is a option in winrar
im not very 1337 with that you just said, but let me see if i hit the ball:
break the .iso up into 2 parts compress it seprately, then burn it onto ONE disk (becuase it's all i have left. lol)
if not, please explain how that would work.
Thanks.
If we're talking text and document-type material, you might be able to do it. If it's programs or multimedia of some form, it would be almost impossible to achieve a compression ratio like that.
That's just about your only option. You won't be able to compress it 35%.
Thanks.
split it into 2 dvd size files, put one on the DVD and the other on the USB flash drive.
You can put it on your USB Flash Drive if your USB Flash drive is big enough (8GB+) you can reformat it to NTFS and than drag and drop the file onto the Flash Drive.
