How to cut the tj07 for a slot loading cd/dvd
548 Views 5 Replies 3 Participants Last post by  oblivion.sky
How to cut the tj07 for a slot loading cd/dvd?
do i use dremel? if so, do i use the fiberglass attachment?
that part of the tj07 seems to be a little thicker than usual...
i want a clean cut for a cd/dvd slot loading drive
thanks in advance.
1 - 6 of 6 Posts
a dremel and a fiberglass reinforced disk for metal will work perfectly
this is how I did it for The Intelligence case
hmm cool, given that i cut it already, can i just nail file the inner edges then spray paint it black for it to blend? would it look obvious?
the case is powdercoated FYI.
You'll have silver edges where you make the cut.
Seems overkill but I used an angle grinder to do it then just feathered the edges with some needle files as required.
Get some little black model paints to touch up the silver edge, or a sharpie, or have it re-coated.
black nail polish will work too
cool! but i definitely dont want to have it recoated
thanks guys!
1 - 6 of 6 Posts
