Seems dangerous though.Originally Posted by Lucky 13 SpeedShop;13104048
Zippo lighter fluid. Much cheaper, and works better than GooGone.
Well sure, if you set it on fire. Common sense would dictate that you don't attempt cleaning the adhesive off near a raging inferno.Originally Posted by Citra;13104059
Seems dangerous though.![]()
I tried that but it wasn't really doing anything. I guess I'll try again.Originally Posted by hirolla888;13104193
90% isopropyl alcohol should do it
your other option i'd say would be to get adhesive remover from the hardware shop. get the stuff that's safe to use on painted surfaces so you don't damage the PSU surfaceOriginally Posted by skwannabe;13104302
Thanks everyone
I'm sorry, but, this is totally something I would do.Originally Posted by Lucky 13 SpeedShop;13104169
Well sure, if you set it on fire. Common sense would dictate that you don't attempt cleaning the adhesive off near a raging inferno.![]()
