1 - 4 of 4 Posts
I rebooted in safe mode and everything. This trojan installed adware which i removed, but left a folder called deluxe communications, within that folder is an empty folder called "microsoft.NET", which I know cant be the real microsoft.net. My question is how do I delete it when its in use, and how the heck can an empty folder be, being used by something. Veyr weird and driving me up a wall, thanks for any help.
The most common way is to delete the file in safe mode.<br />
<br />
I find that the easiest way is by using this program called Unlocker.<br />
<br />
You can get it here: <a href="http://ccollomb.free.fr/unlocker/" target="_blank">http://ccollomb.free.fr/unlocker/</a>
or try doing it from cmd (command prompt), so its like:<br />
<tr>
<b>del /f /s <i>filename</i></b>
</td>
</tr>
</table>
</div>if stuck type in <b>del /?</b> and hit enter to see how the syntax works
Discussion Starter #4
I have done everything humanly possible to delete this folder, sceduled a boot delete, tried killbox, EVERYTHING but access is denied to the folder.... Getting irritated, bt dont want to reformat because my monitor was flashing black and I think I changed some settings when I first got it, so it works good now, and I dont want to screw it up again...
1 - 4 of 4 Posts
