Originally Posted by Ty Auchter After your first WU is done your score will show up on their website (It might take an hour). Post in the thread called. "Folders Check In Here," with the name you gave it during setup. It might take a day or two, but you'll get the red protein postbit and your team rank will be there as well. EDIT: To get it to run faster hit Ctrl+Alt+Del and find the process (FahCore_##.exe) and raise it's thread priority. Don't raise it above Normal or you might start having other programs get slow. I also raise Explorer.exe to High just to be sure everything will run smoothly. And yes, it'll pick up where it left off. |
