http://www.overclock.net/ati/966436-6950-cf-bsod-ab-trixx.html
Fourth post from the top. Enjoy. My overclocks are with that method.
1) Backup the registry.
2) Copy the one shown in post to notepad.
3) Ensure AMD Overdrive is checked on.
4) Merge registry.
5) Reboot. And voila - you are done.
No voltage control though. But you can get to 920/1400 on stock. If you want to apply voltage, you will have to mod your BIOS using RBE.
4) Merge registry.
