1 - 5 of 5 Posts
Programmer
Remove the 60 Hz lock in HITMAN 2016 on the PC.
This guide is for those running panels capable of refresh rates higher than 60 Hz. The issue is that the game can't utilize a refresh rate higher than 60 Hz under certain circumstances as explained below:
D3D11:
Windowed - No refresh rate lock.
Full Screen - No refresh rate lock.
Exclusive Full Screen - 60 Hz lock.
D3D12:
Running the game in Window and Full Screen mode via D3D11 removes the refresh lock, but that's not ideal for those wanting D3D12, CrossFire-X or the performance benefits of Exclusive Full Screen in D3D11 mode. The first fix was very simple ("Was" being the key word. More on that later):
1) Click the start button
2) Type regedit and press enter
3) Navigate to HKEY_CURRENT_USER / SOFTWARE / IO Interactive / Hitman
4) Find a key called Refreshrate
5) Edit the value to match your highest refresh rate possible.
After patch 1.1.0. this fix no longer worked. It is still broken as of version 1.1.2. Here is the new fix I've formulated:
Solution:
1) Download and run CRU.
2) Select your active display from the top drop down menu.
3) Click on your resolution under "Detailed resolutions" and click edit.
4) A new menu will open. Click the "timing" drop down menu at the top of the window and select "Automatic LCD standard".
5) Type your highest stable refresh rate under "Frequency". Click OK. The new window will now close.
6) Select "No Extension Block" near the bottom of the program. Click OK.
7) Run restart64.exe file to enable the changes.
Additional Information:
Don't confuse Refresh Rate lock with an FPS lock. They are two completely different things! This guide might not work without additional tweaking for those running downsampling and/or overclocked refresh rates.
Troubleshooting:
The game will only run at 1080p after applying the CRU fix? Here's the solution:
1) Open CRU, again
2) At the bottom of "Established resolutions", click None.
3) At the bottom of "Standard resolutions", click Delete all.
4) Click OK at the bottom of the program's window and run restart64.exe to apply changes.
Programmer
Discussion Starter #2
OP updated.
1) Formatting fixed.
2) Useless information removed.
Programmer
OP updated.
1) Added Resolution Fix
2) Added Troubleshooting Section.
3) Changed Format For Easy Reading.
Programmer
Discussion Starter #4
OP update.
1) DX12 render path not working, solution found and added.
Programmer
Discussion Starter #5
Information Update:
New patch added to the game today, (approx. 128MB) via Steam. This addresses the D3D12 path issue.
OP Update:
1) D3D12 fix removed. (Fix will be archived below):
My game won't launch in DX12 mode after patch 1.1.2. The app hangs in task manager, what should I do?
1) Launch via the DX12 executable located in the game's DIR, then click Play on launcher.
2) Wait for up to 15 minutes, the application should launch during ot after this time.
1 - 5 of 5 Posts
