1 - 10 of 10 Posts
First -- expletive Asus. This G751 I have, Asus partitioned the OS drive to heck. But here's the problem:
1. EFI partition
2. OS partition
3. Recovery partition
4. data partition
Whuh... why???
I can't find any way to get rid of that D: 100gb data partition and put the space into the C: partition. As far as I know it's not possible, since the unallocated space has to be adjacent, and the Recovery partition that sits in between cannot be extended shrunk etc.
Anyone know how to do this??
Ultra wide wide wide.....
I've ran into this problem before. What I used to set everything to the way I wanted was AOMEI Partition Assistant. Worked like a charm.
Discussion Starter #4
How? AOMEI says
You can only merge 2 partitions in one time, and the two partitions must be adjacent.
http://www.disk-partition.com/help/merge-partition.html
So did you shrink the OS partition and create an unallocated space, and then merge that with the non-adjacent partition you want to get rid of? I
ll install and try it, but that's the only thing I can think of, and I don't know if that function works that way.
The ONLY way i've done this, i used a linux live usb/cd to run gparted (or you just run gparted on a usb alone) and what basically needed to happen was partitions had to be moved (technically rewritten). However the wonderful thing is you can chain all the moves, even the expanding to the unallocated space with gparted, but it will take a while.
I did that a long time ago, I don't remember what I did exactly but I know the AOMEI was the only one that did what I wanted out of a bunch of others that I tried.
Discussion Starter #7
Well I'm mystified how you did it, anything I try with non adjacent spaces gets greyed out.
You might need to move one partition at a time.
Reactions: taem
Discussion Starter #9
Hey Cyclops --
Thanks tons man! Worked. Turns out I was being stupid and trying to manipulate from the bottom window, which shows the same info in a different way. But you have to use the top window for *this* function -- other functions work fine off the bottom window. I have no idea why they did it that way. Maybe preOS stuff is reserved for the top window.
1 - 10 of 10 Posts
