1 - 3 of 3 Posts
Can i just put the multi on the lowest and ramp up blk to 220 or something and test system with prime?
is that how u find highest blk?
I wouldn't put it on lowest, I would use the multi to keep your chip running at a speed you know is within its capabilities. But essentially, yes, lower multi, raise BLK
problem is im using stock cooler so theres a limit on what i can oc for the moment but im doin to to determine if its worth purchasing a high end heatsink
1 - 3 of 3 Posts
