1 - 11 of 11 Posts
Hello, i was wondering if anyone could help telling me how to do this.
I was wondering what the pros and cons are.
I want to know what happens if it screws up.
Just bought this for my new rig
(thanks Powertrip)
Administrator
Well Il leave the flashing instructions to someone else.
However ill give you the pro's and Cons:
Pro's:
Increased Core and memory speeds leading to better FPS in most cases ( Depends on the new BIOS used )
Can Unlock more Piplines once again leading to better overall peformance and FPS.
Cons:
Heat Increase with core and mem speed increase
Faulty pipelines may be unlocked leading to artifacting and Instability in 3D mode.
If you where to hit a problem all you have to do is flash your card back to its stock BIOS.
I have no idea what you can flash it to
But you will need atiflash that is can be found at techpowerup so can all the bioses
Filthy Casual
Take a camera, take a picture of your card with flash on. Done! (Sorry, couldn't resist
lol, well depending on what core you have will determine what it will be flashed to
Filthy Casual
Look at the FAQ I linked to, you can flash to e ither an x800XT or an x850XT/PE
But that depends on what core he has
Filthy Casual
His is the R423 core, which means it can be flashed to the x800XT.
I never bothered, though.
1 - 11 of 11 Posts
