How to get 10k 3dmarks?
2438 Views 63 Replies 22 Participants Last post by  thlnk3r
I've current got 9,508
Everything at stock speeds, except I've got my video card OCed to 675MHz core and 1050MHz memory.
1 - 20 of 64 Posts
Even a modest OC on that CPU will increase your score. You could probably come close to 10K running at a 3.0 - 3.2GHz
put your chip at 3ghz and that should help
That's where I need help... lol
BRB, taking pics of BIOS
Orrr... Buy a Phenom X4 with 95W TDP max, along with DDR2-1066 2GB RAM.
try raising cpu frequency to 215 and see what happens
7
Originally Posted by AlphaDog11790
OC your 5000+ some.
Originally Posted by x2s3w4
3Dmark06 is very CPU dependent. OC that CPU.
Originally Posted by jrharvey
your CPU is definately holding you back here. You need to OC it some more.
Originally Posted by G|F.E.A.D|Killa
oc your CPU
I think you should OC that processor.... maybe....
Way to be redundant... lol.
Bumped it to 215, 2.8GHz now.
Dling Prime95 now.
No way that I saw to unlink my RAM and CPU FSB, oh well.
Someone else on here said they got it up to 800MHz, it's at 700MHz now.
can you set it on a lower multi
Doubt it.
I posted pics of my BIOS in post #9.
Tried 235MHz bus speed, failed.
230MHz, failed, 225MHz failed, 220MHz, Worker thread #2 failed, #1 is still going.
Probably need more vcore?
you can set your ram on a lower multi?
Looks like int he second pic "memory timing" set that to manual then post a pic of what your options are. Im betting you can set the frequency lower.
-Ω.
Manually set it to 667MHz for RAM.
Bumped bus speed back to 220MHz, RAM speed still went up .
set ram to 533.
ram moves dependent on the ram multi to teh fsb
Yep, the ram speed will always depend on the reference clock, as well as the CPU multi. There is a nice chart HERE, that will show you what I mean.
There is another option... you can just set your CPU multi to 15 and you'll be at 3GHz right away, although you might need a little more vcore at some point. My friends BE runs at 3.1GHz at stock voltage... so you should be good to go.
I just got my 4600 brisbane up to 3GHz (left my window open at night... and in the morning had low enough temps to get a little more out of it.. i was idleing at 13c, instead of 22...), and with my new 9800GT (non OC'd) I score 10087 in 3Dmark06, so I think that once you get your BE up to 3.0-3.2GHz, that you'll definitely beat that.
Good luck.
1 - 20 of 64 Posts
