How to get a huge air bubble out?
1197 Views 19 Replies 9 Participants Last post by  Dryadsoul
my system is setup a little different than what i have seen everyone else running. mine runs as follows:
pump>rad>cpu>res>gpu>pump
i cant seem to get a bubble out that is running through my pump. i have my res open when i can but it seems ill have to take everything out to get it out. unless anyone has any suggestions.
1 - 20 of 20 Posts
try turning everything off and tilting your case to get the air bubble down to your res, though i cant see why the pump just didnt get rid of once it started flowing:s
shake the pump. I have my T line right before the inlet of the pump. I always get bubbles between the outlet and the rad. Once I get it as bled as I can, there is always a bubble in the outlet. I turn the pump off, aim the inlet up and rapidly shake the bump. This gets the bubble on the other side of the impeller and out the T line. It will take a little while, but eventually, you'll get it.
Also, I would rearrange that loop. It is going to be tough to get that bubble through the rad and CPU block and out the res.
the reason just turning the pump on wont move it is because the bubble runs all the way through the pump so it doesnt actually have any water to move. this is my first loop to so blegh im bound to have some troubles.
Pinching (kinda violently and quickly) the tubing in between each component will disrupt the flow to dislodge some bubbles (while the loop is running). I generally do this when the only the loop has power and there is no power to the system.
Also as stated, gently shaking the case and tilting in various directions will help to bleed the loop. Just take care not to orient the case so that air does not get pulled in from the reservoirs outlet to the loop.
If you have to pull it apart, I suggest placing the res before the pump if possible.
Otherwise you've already gotten the best advice.
I assume you know that running a dry pump is bad news? Also, you may want to unhook one of the lines and try to prime the pump as much as possible. (as in, pouring coolant right down on tube trying to get as much fluid into the loop as possible before running the pump) This is usually no big deal if the fill (being either a res or a T line) is right before the inlet of the pump.
Also, do you know how to jump a PSU to run the pump by itself without firing up the whole system? You need to do this to bleed and leak test. If you fire up the rig and have low flow (or no flow) due to air, the CPU etc. can overheat.
yep have it the psu jumpered. and my mobo is not powered on at all. i havent been running my pump dry either. i think i may just end up rearranging everything.
reservoir must always be before pump... reconfigure your setup. to get the buble out bleed through the res while pump is running
the only reason i ran my res before my gpu was because i didnt think i would be able to come down from my cpu into my gpu then back up to my res about 5 inches. would an mcp655 be able to do that?
as far as restriction goes im not sure how this fares so i will list the parts im using.
pump:mcp655
cpu: stinger v8
gpu: xspx razor 4870x2
rad: 480 gtx
res: koolance 120mm
all running on 1/2in barbs.
if im going to end up rearranging im taking out my damn compression barbs. i hate them! there pretty but i cant seem to get them together in less than an hour
I'm running the same WB and pump with a 3 liter res, and here's the kind of bends my MasterKleer tubing allows(this is the other mobo in my loop):
My tubing is not quite as forgiving. 1/2" ID (3/4" OD) is huge compared to most i see in pics :-0
When I peiced my system together (first w/c build) I did it all unused, the only part in its correct spot was the RAD, which i didnt hook up to the case and let hang so it was at lowest point, I put my res at the highest point and was able to stretch and move and bend whil running to get all bubbles out...
The hard part comes when trying to put the cpu block on and then get the board into the case with all the tubing etc.... grrrr
but I suggest having everything unmounted and stretch it out til the res is at the highest point, then tweak each component until the air finds its way to the top.
so rad has to be the lowest point? i have it on top of my haf 932 sideways. didnt think it would be an issue but may as well check. no where else the damn thing will fit.
pump:mcp655
cpu: stinger v8
rad: 480 gtx
res: koolance 120mm
In a closed loop, height of items relative to each other doesn't come into play as far as how much pressure the pump can produce.
The only thing that is really important for height placement is to make sure your res is higher than your pump so it can gravity feed the pump to reduce dry starts.
It doesnt have tp be but it's so much easier so air doesnt get trapped. Titl your case so the barbs are higher than the other end of the rad and it should help work the air out of it. As for the pump I had the same issue. It's obnoxious and time consuming but pinching like Syr said and powering the pump on for short bursts works as well.
Pump needs to be at lowest point possible and the res at the highest point;
if you run Res>>>Pump>>>Rad>>>Blocks>>>Res, the rad can be anywhere.
its amazing how much easier it is to get rid of bubbles after moving the res before the pump. almost instantly all my air was out.
leak testing right now and pics to come soon.
how long should i leak test before i can set it all back up and jam? im anxious to add my dye and pt nuke
If all the tubes clamped an hour should suffice, but don't leave it run overnight in case it develops a weep.
1 - 20 of 20 Posts
