How to get more then 1.25 volts on my 6990?
520 Views 9 Replies 7 Participants Last post by  fazio93
How can i get more voltage then the 1.125? I can get stable with 1.125 at 1020/1320 but i really want around 1050/1350. How can i up the voltage even more? im on water cooling and max temps are 52 with 1.125 volts
1 - 10 of 10 Posts
that has been removed the program, any other way? or is 1.125 the best to max?
there is an unofficial Ab that allows up to 1.5v but its very exclusive and used by the extreme guys
no it hasn't
http://www.overclock.net/ati/861293-...l#post11258246
No it wasn't, it was just changed. In your MSIafterburner.cfg, under the [ATIADLHAL] line, you should make it:
UnofficialOverclockingEULA= I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
UnofficialOverclockingMode= 1
AccessibilityCheckingPeriod= 0
i tried to edit the cfg file, still no luck, tried 2.0 version no luck. Any where i can change the voltage? i cant find that program where the link was given, if someone has the download link that'd be great
Just flash your card to the asus eah6990 and Use the Asus Smart Doctor 590/580 . The current voltage limit is 1,4Volt
this?
http://www.mediafire.com/?t5mh9j185eru4k5
1 - 10 of 10 Posts
