1 - 6 of 6 Posts
I think you would have to use a mini display port as your 3rd output. If your card does not have one then I dont think you can use 3 monitors.
Discussion Starter · #6 ·
Originally Posted by DaXxJaPxX;15353651
you can use a hdmi for the third card. the only thing you have to do is make sure you use an active display port(or active mini dp, depending on ur card) for one of the monitors. the other 2 can be dvi, hdmi, or 1 of each
Do I have to buy an active display port like this?
It costs $32, might be cheaper to just get a pci card like GT520 or FX5500 for additional dvi out
If I buy an HD6850 now, do I still need to buy active display port?
Here's a photo of the back if it helps
1 - 6 of 6 Posts
