What is your ram voltage at?
Not high for 6800. That m die or a?1.4v
I dont knowNot high for 6800. That m die or a?
I dont have ram fan you say if i stay in 6800mhz to change trefi to 65536 or 130560?If A-Die, just run the Asus 7600 Preset and change TREFI to auto. If you have a ram fan, you probably could try running 65536/130560 for TREFI. You have to run TM5 to test and see how you fare for temps.
That's even provided your Z690 Hero can run 7600 with no issues.
I also have a 6800CL30 profile for my M-die that I just finished. If you're interested I'd like to compare. I will post or DM you mine tonight when I'm home.If A-Die, just run the Asus 7600 Preset and change TREFI to auto. If you have a ram fan, you probably could try running 65536/130560 for TREFI. You have to run TM5 to test and see how you fare for temps.
That's even provided your Z690 Hero can run 7600 with no issues. If you have M-Die, you can try my 6800C30 profile if you want but it runs 1.55V VDD/VDDQ.
Can you pm the bios txt file or post here would be great. See what works for you.I also have a 6800CL30 profile for my M-die that I just finished. If you're interested I'd like to compare. I will post or DM you mine tonight when I'm home.
Unfortunately I've already moved to A-Die. Thanks for the offer though. 👍I also have a 6800CL30 profile for my M-die that I just finished. If you're interested I'd like to compare. I will post or DM you mine tonight when I'm home.
Here you go.Can you pm the bios txt file or post here would be great. See what works for you.
My mobo has super low VCCSA for some reason. It defaults to .938V. I have it like +90 mV in FIVR settings. Just got this setup stable, ran 65000 REFI for tests, tho. Even 1C exterior temps and a Corsair Vengeance DIMM fan at full speed with my bedroom window open couldn't do MAX REFI temp-wise.Can you pm the bios txt file or post here would be great. See what works for you.
Yep. Tried different combinations of p/e/ring ratios, this ratio scaled better for benching and ram bandwidth. Its 54x all core p, 45 e, 49 ring.Not sure on asrock board how to. See your running 103 bus clock?
