How to increase Vcore on Asus M3A78-EM?
1551 Views 2 Replies 2 Participants Last post by  supernova7
Does anybody know how to increase the Vcore/VID on the motherboard M3A78-EM?
1 - 3 of 3 Posts
Advanced ==> JumperFree Configuration (this is where your clocks and voltage are changed)
Processor Voltage (can only set Auto, +0.05, +0.1, +0.15)
Memory OverVoltage (Auto and + or - to change).
If you're asking about Video, then it is
Chipset OverVoltage (again, Auto, +0.05, +0.1, +0.15) (max speed I got with artifacts was 875MHz, max stable is 850MHz at +0.15V - or 700MHz without any extra V)
If you lock up your PC (No POST), reset and hit del repeatedly and it will let you boot up to BIOS with default settings.
The processor voltage is barely any so it seems worthless.
1 - 3 of 3 Posts
