1 - 5 of 5 Posts
How does the heatsink go on?
Remove the original heatsink?
Wood Automotive exterior Bumper Rectangle Auto part
Wood Rectangle Line Gas Automotive exterior
Black Circuit component Microcontroller Font Hardware programmer
Circuit component Passive circuit component Hardware programmer Electronic engineering Computer hardware
I think that heatsink is only for the M.2 slot closest to the CPU socket. It's not for the M.2 slot you used.
Graphics Junkie
^ this is accurate
Don't remove the heatsink sticker from the SSD, just stick the one that came with your mobo on top.
Top slot won't (shouldn't) work for the i5 10600K (assuming his signature is accurate). It is for RKL only. Could try to stick it on the bottom slot. Might lose some sata ports depending on which slot you use, but if you don't need all of em, shouldn't make a difference.
Reactions: The Pook
I have 6 sata devices, might be raiding 2, does raid require sata 1 & 2 port if so i'll have to move my m.2 to the third m.2 port. I also have a sata 3 vantec 4 port raid card.
Msi z590 a pro
STORAGE
6x SATA 6Gb/s ports (from Z590 chipset)
3x M.2 slots (Key M)
M2_1 slot (from CPU) 1
Available only on 11th Gen Intel® CPU
Supports up to PCIe 4.0x4
Supports 2242/ 2260/ 2280/ 22110 storage devices
M2_21, M2_32 slots (from Z590 chipset)
Support up to PCIe 3.0x4
Support up to SATA 6Gb/s
Support 2242/ 2260/ 2280 storage devices
Intel® Optane™ Memory Ready 3
Support Intel® Smart Response Technology for Intel Core™ processors
SATA2 will be unavailable when installing M.2 SATA SSD in the M2_2 slot.SATA5 & SATA 6 will be unavailable when installing M.2 SSD in the M2_3 slot.Before using Intel® Optane™ memory modules, please ensure that you have updated the drivers and BIOS to the latest version from MSI website.
1 - 5 of 5 Posts
