1 - 2 of 2 Posts
I would like to know if there is any way to set a key to left click on a set spot on the screen. For instance, when gaming... Say your cursor is at spot A, but you want to click something located at spot B... Is there any way to generate a left-click in spot B without moving your cursor there? (by pressing another key) Or, is there any way to make your cursor immediately jerk to spot B? Thanks.
................ A
.............................. B. |
You would have to know the exact location of the place you want to click. Once you know that it'd be easy to write a program to simulate a left click at the x, y location
1 - 2 of 2 Posts
