1 - 4 of 4 Posts
I found them. What I don't like is that they're doing white LED on white fittings. The chrome ones has blue LED's.
Also, would 1 be enough or should I get 2... 1 on each end?
My Mod Toys also has a ton of them here
Or you can spin your own with a blank one here
As far as one or two, LED's shining through water scatter the light nicely so it really depends on how bright you want the effect. One would work great in a tube res, more = brighter.
1 - 4 of 4 Posts
