How to limit RAM mhz, help!
342 Views 6 Replies 7 Participants Last post by  BlankThis
Is there anyway to limit the RAM Mhz freq??
My clocks are getting ****ed up if i OC my computer to 3Ghz
ram goes from 800 mhz up to 900mhz (i want to keep it at 800)
Any way to "lock" the ram at same freq?
1 - 7 of 7 Posts
No, when you overclock your FSB, you also overclock the RAM
Set your ram to DDR2-667. Done.
Why do you want to limit your RAM? Those sticks should do 900 MHz without an issue.
There should be a way to set the ratio of your ram in the bios. You might have to underclock it at 1st to find your max CPU OC.
My ram is set to 3.0 default. I think that you will look for a ram multiplier, if you set that to 2, then if the fsb is 400, then the ram is 800 mhz. I can get up to 550 fsb with my ram
You may be able to unlink your RAM which means your FSB won't affect your RAM when it's raised. Also try changing the ratio so that your RAM clocks are lowered.
~B~
1 - 7 of 7 Posts
