1 - 16 of 16 Posts
# First off this entire post is a working<br>
#configuration file found in "/etc/X11/" [thats with a capital X]<br>
#called your "xorg.conf" file<br>
#this guide will be helpful in setting up anything graphical to a point.<br>
#this guide assumes you're using ubuntu<br>
# open a "run command dialog or terminal and enter "gtksu gedit /etc/X11/xorg.config"<br>
#and you will be presented with this file<br><br><br>
#still updateing<br><br>
# ************************************************** ********************<br>
# Module section -- this section is used to specify<br>
# which dynamically loadable modules to load.<br>
#<br>
Section "Module"<br><br>
# This loads the DBE extension module.<br><br>
Load "dbe" # Double buffer extension<br><br>
# This loads the miscellaneous extensions module, and disables<br>
# initialisation of the XFree86-DGA extension within that module.<br>
SubSection "extmod"<br>
Option "omit xfree86-dga" # don't initialise the DGA extension<br>
EndSubSection<br><br>
# This loads the font modules<br>
Load "type1"<br>
Load "freetype"<br>
#Load "speedo"<br>
#Load "dri" #not needed for nvidia users<br>
# This loads the GLX module<br>
Load "glx"<br><br>
#the following modules are loaded [by defalt] in ubuntu some are needed for multi monitoring<br>
# ie they will work with any driver<br><br>
Load"bitmap"<br>
Load"ddc"<br>
Load"extmod"<br>
Load"int10"<br>
Load"record"<br>
Load"v4l"<br>
Load"vbe"<br><br>
EndSection<br><br>
# Files section. This allows default font and rgb paths to be set<br>
# ************************************************** ********************<br><br>
Section "Files"<br><br>
# The location of the RGB database. Note, this is the name of the<br>
# file minus the extension (like ".txt" or ".db"). There is normally<br>
# no need to change the default.<br><br>
RgbPath"/usr/X11R6/lib/X11/rgb"<br><br>
# Multiple FontPath entries are allowed (which are concatenated together),<br>
# as well as specifying multiple comma-separated entries in one FontPath<br>
# command (or a combination of both methods)<br>
#<br>
# If you don't have a floating point coprocessor and emacs, Mosaic or other<br>
# programs take long to start up, try moving the Type1 and Speedo directory<br>
# to the end of this list (or comment them out).<br>
#<br><br>
FontPath "/usr/X11R6/lib/X11/fonts/local/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/misc/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"<br>
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"<br>
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/CID/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"<br>
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic/"<br><br>
# WARNING: Thies are generic paths<br><br>
# ModulePath can be used to set a search path for the X server modules.<br>
# The default path is shown here.<br><br>
# ModulePath "/usr/X11R6/lib/modules"<br><br>
EndSection<br><br>
#here is the composite option [for tranceparency]<br>
#Section "Extensions"<br>
# Option "Composite" "true"<br>
#EndSection<br><br><br><br>
# Server flags section.<br>
Section "ServerFlags"<br><br>
# Uncomment this to cause a core dump at the spot where a signal is<br>
# received. This may leave the console in an unusable state, but may<br>
# provide a better stack trace in the core dump to aid in debugging<br><br>
# Option "NoTrapSignals"<br><br>
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence<br>
# (where n is 1 through 12). This allows clients to receive these key<br>
# events.<br><br>
# Option "DontVTSwitch"<br><br>
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence<br>
# This allows clients to receive this key event.<br><br>
# Option "DontZap"<br><br>
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching<br>
# sequences. This allows clients to receive these key events.<br>
#<br>
# Option "DontZoom"<br><br>
# Uncomment this to disable tuning with the xvidtune client. With<br>
# it the client can still run and fetch card and monitor attributes,<br>
# but it will not be allowed to change them. If it tries it will<br>
# receive a protocol error.<br><br>
# Option "DisableVidModeExtension"<br><br>
# Uncomment this to enable the use of a non-local xvidtune client.<br><br>
# Option "AllowNonLocalXvidtune"<br><br>
# Uncomment this to disable dynamically modifying the input device<br>
# (mouse and keyboard) settings.<br><br>
# Option "DisableModInDev"<br><br>
# Uncomment this to enable the use of a non-local client to<br>
# change the keyboard or mouse settings (currently only xset).<br><br>
# Option "AllowNonLocalModInDev"<br><br>
# Set the basic blanking screen saver timeout.<br><br>
# Option "blank time" "10" # 10 minutes<br><br>
# Set the DPMS timeouts. These are set here because they are global<br>
# rather than screen-specific. These settings alone don't enable DPMS.<br>
# It is enabled per-screen (or per-monitor), and even then only when<br>
# the driver supports it.<br><br>
# Option "standby time" "20"<br>
# Option "suspend time" "30"<br>
# Option "off time" "60"<br><br>
# On some platform the server needs to estimate the sizes of PCI<br>
# memory and pio ranges. This is done by assuming that PCI ranges<br>
# don't overlap. Some broken BIOSes tend to set ranges of inactive<br>
# devices wrong. Here one can adjust how aggressive the assumptions<br>
# should be. Default is 0.<br><br>
# Option "EstimateSizesAggresively" "0"<br><br>
EndSection<br>
# Input devices<br>
# Core keyboard's InputDevice section<br>
Section "InputDevice"<br><br>
Identifier"Keyboard1"<br>
Driver"kbd"<br>
# For most OSs the protocol can be omitted (it defaults to "Standard").<br>
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),<br>
# uncomment the following line.<br><br>
# Option "Protocol" "Xqueue"<br><br>
# Set the keyboard auto repeat parameters. Not all platforms implement<br>
# this.<br><br>
# Option "AutoRepeat" "500 5"<br><br>
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).<br><br>
# Option "Xleds" "1 2 3"<br><br>
# To disable the XKEYBOARD extension, uncomment XkbDisable.<br><br>
# Option "XkbDisable"<br><br>
# To customise the XKB settings to suit your keyboard, modify the<br>
# lines below (which are the defaults). For example, for a European<br>
# keyboard, you will probably want to use one of:<br>
#<br>
# Option "XkbModel" "pc102"<br>
# Option "XkbModel" "pc105"<br>
#<br>
# If you have a Microsoft Natural keyboard, you can use:<br>
#<br>
# Option "XkbModel" "microsoft"<br>
#<br>
# If you have a US "windows" keyboard you will want:<br>
#<br>
# Option "XkbModel" "pc104"<br>
#<br>
# Then to change the language, change the Layout setting.<br>
# For example, a german layout can be obtained with:<br>
#<br>
# Option "XkbLayout" "de"<br>
#<br>
# or:<br>
#<br>
# Option "XkbVariant" "nodeadkeys"<br>
#<br>
# If you'd like to switch the positions of your capslock and<br>
# control keys, use:<br>
#<br>
# Option "XkbOptions" "ctrl:swapcaps"<br><br><br>
# These are the default XKB settings for X.Org<br>
#<br>
# Option "XkbRules" "xorg"<br>
# Option "XkbModel" "pc101"<br>
# Option "XkbLayout" "us"<br>
# Option "XkbVariant" ""<br>
# Option "XkbOptions" ""<br><br>
EndSection<br>
# Core Pointer's InputDevice section<br>
# Identifier and driver<br><br>
Identifier"Mouse1"<br>
Driver"mouse"<br><br>
Option"ZAxisMapping" "4 5"<br>
Option"Buttons" "3"<br><br>
# On platforms where PnP mouse detection is supported the following<br>
# protocol setting can be used when using a newer PnP mouse:<br><br>
# Option "Protocol" "Auto"<br><br>
# The available mouse protocols types that you can set below are:<br>
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2<br>
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2<br>
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse<br>
# ThinkingMouse ThinkingMousePS/2 Xqueue<br>
Option "Protocol" "IMPS/2"<br><br>
# The mouse device. The device is normally set to /dev/mouse,<br>
# which is usually a symbolic link to the real device,<br>
#and on some systems "/dev/mice" is a symbolic link to all mice<br><br>
Option "Device" "/dev/mouse"<br>
# Option "Device" "/dev/psaux"<br>
# Option "Device" "/dev/ttyS0"<br>
# Option "Device" "/dev/ttyS1"<br><br>
# When using XQUEUE, comment out the above two lines, and uncomment<br>
# the following line.<br><br>
# Option "Protocol""Xqueue"<br><br>
# Baudrate and SampleRate are only for some Logitech mice. In<br>
# almost every case these lines should be omitted.<br><br>
# Option "BaudRate""9600"<br>
# Option "SampleRate""150"<br><br>
# Emulate3Buttons is an option for 2-button Microsoft mice<br>
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)<br><br>
# Option "Emulate3Buttons"<br>
# Option "Emulate3Timeout" "50"<br><br>
# ChordMiddle is an option for some 3-button Logitech mice<br><br>
# Option "ChordMiddle"<br><br>
EndSection<br><br>
# Some examples of extended input devices<br><br>
# Section "InputDevice"<br>
# Identifier "spaceball"<br>
# Driver "magellan"<br>
# Option "Device" "/dev/cua0"<br>
# EndSection<br>
#<br>
# Identifier "spaceball2"<br>
# Driver "spaceorb"<br>
# EndSection<br>
#<br>
# Identifier "touchscreen0"<br>
# Driver "microtouch"<br>
# Option "MinX" "1412"<br>
# Option "MaxX" "15184"<br>
# Option "MinY" "15372"<br>
# Option "MaxY" "1230"<br>
# Option "ScreenNumber" "0"<br>
# Option "ReportingMode" "Scaled"<br>
# Option "ButtonNumber" "1"<br>
# Option "SendCoreEvents"<br>
# EndSection<br>
#<br>
# Identifier "touchscreen1"<br>
# Driver "elo2300"<br>
# Option "MinX" "231"<br>
# Option "MaxX" "3868"<br>
# Option "MinY" "3858"<br>
# Option "MaxY" "272"<br>
# Option "ButtonThreshold" "17"<br>
# EndSection<br><br>
# Monitor section<br>
# Any number of monitor sections may be present<br><br>
Section "Monitor"<br><br>
Identifier "My Monitor"<br>
#HorizSync determins your monitors maximum resolution<br>
#[note: it is possible to "overclock" your monitor if you use the correct number]<br>
# HorizSync is in kHz unless units are specified.<br>
# HorizSync may be a comma separated list of discrete values, or a<br>
# comma separated list of ranges of values.<br>
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR #MONITOR'S<br>
# USER MANUAL FOR THE CORRECT NUMBERS.<br><br>
HorizSync 31.5 - 150.0<br><br>
#Be sure to get this right because it determins<br>
#what resolutions your monitor can handle<br>
#state the entire range supported by your monitor<br><br>
# HorizSync30-64 # multisync<br>
# HorizSync31.5, 35.2 # multiple fixed sync frequencies<br>
# HorizSync15-25, 30-50 # multiple ranges of sync frequencies<br><br>
# VertRefresh is in Hz unless units are specified.<br>
# VertRefresh may be a comma separated list of discrete values, or a<br>
VertRefresh 75-85<br><br>
# this is your "refresh rate" range<br><br>
# Graphics device section<br>
# Any number of graphics device sections may be present<br>
# there can be non working sections so long as they are not menend in the working screens section<br><br>
Section "Device"<br>
Identifier "VESA Framebuffer"<br>
Driver "vesa"<br>
#this section is how the vesa framebuffer should be called for xserver<br>
Endsection<br><br>
# install the non-open source drivers to use hardware rendering<br>
# for nvidia see below<br>
#for ati users this is "fglrx"<br><br>
#BusID "PCI:x:x:x:<br>
#were :x:x:x: is you should use a bus ID givien by the results<br>
#of this command "lspci" [and look for vga compatible controller]<br>
# the results are in this formatt 01:06.0 treat each of the symbols as a colon i.e.<br>
#it should look like this "PCI:01:06:0" or this "PCI:1:6:0"<br>
#WARNING Do not use this option with the VESA Framebuffer<br><br>
# Option "RenderAccel" "true"<br>
# for 3d rendering<br><br>
#Option "backingstore" "true"<br>
#this will probably work on any driver to help rendering but is recommended for nvidia and ati<br>
#screen 0<br>
#this is needed to determine which port this on your gfx card this device is for,<br>
#unless you are using twinview<br><br>
#VideoRam 4096<br>
# Insert Clocks lines here if appropriate<br><br><br>
#for nivdia only<br>
#Section "Device"<br>
Identifier"nvidia"<br>
Driver"nvidia"<br>
BusID"PCI:1:6:0"<br>
#for 3D rendering<br><br>
#this will probably work on any driver to help rendering but is recommended for nvidia and #ati<br><br>
Option "coolbits" "1"<br>
# nvidia only, hardware monitoring<br><br><br>
Option "TwinView"<br>
Option "Logo" "1"<br>
#turns the logo on and off<br>
Option "TwinViewOrientation" "Clone"<br>
#Option "SecondMonitorHorizSync" "30-50"<br>
#Option "SecondMonitorVertRefresh" "60"<br>
#Option "MetaModes" "1280x1024,1024x768 @1280x1024;1024x768,1024x768; 800x600,800x600; "<br>
#Option "ConnectedMonitor" "CRT,TV"<br>
#twinview, were do i begin? look at the nvidia linux driver's readme<br><br><br><br>
#EndSection<br><br><br><br><br>
# Screen sections<br>
# Any number of screen sections may be present. Each describes<br>
# the configuration of a single screen. A single specific screen section<br>
# may be specified from the X server command line with the "-screen"<br>
# option.<br>
Section "Screen"<br>
Identifier "Screen 1"<br>
Device "VESA Framebuffer"<br>
Monitor "My Monitor"<br><br>
# If your card can handle it, a higher default color depth<br>
# is highly recommended.<br><br>
# DefaultDepth 8<br>
# DefaultDepth 16<br>
DefaultDepth 24<br><br>
# "1024x768" is also a conservative usable default resolution. If you<br>
# have a better monitor, feel free to try resolutions such as<br>
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever #your<br>
# card/monitor can produce)<br>
#[note: to "overclock" your monitor add the next<br>
#resolution supported by your gfx card, lower your refresh rate and set<br>
#your resolution to one you added earlyer]<br>
#Viewport 0 0<br>
Subsection "Display"<br>
Depth 8<br>
Modes "1024x768" "800x600" "640x480"<br>
EndSubsection<br>
Depth 16<br>
EndSubsection<br>
Depth 24<br>
EndSubsection<br>
#NOTE there is no such thing as 32 bit depth, alot of deveopers miss this<br>
# the first modes option is the defalt , these options may #be 1:"[email protected]" or 2:"1024x768",<br>
#in number 2 the<br>
# highest supported refresh rate is default<br>
# ServerLayout sections.<br>
# Any number of ServerLayout sections may be present. Each describes<br>
# the way multiple screens are organised. A specific ServerLayout<br>
# section may be specified from the X server command line with the<br>
# "-layout" option. In the absence of this, the first section is used.<br>
# When now ServerLayout section is present, the first Screen section<br>
# is used alone.<br><br>
Section "ServerLayout"<br><br>
# The Identifier line must be present<br>
Identifier "Simple Layout"<br><br>
# Each Screen line specifies a Screen section name, and optionally<br>
# the relative position of other screens. The four names after<br>
# primary screen name are the screens to the top, bottom, left and right<br>
# of the primary screen. In this example, screen 2 is located to the<br>
# right of screen 1.<br><br>
Screen "Screen 1"<br><br>
# Each InputDevice line specifies an InputDevice section name and<br>
# optionally some options to specify the way the device is to be<br>
# used. Those options include "CorePointer", "CoreKeyboard" and<br>
# "SendCoreEvents".<br><br>
InputDevice "Mouse1" "CorePointer"<br>
InputDevice "Keyboard1" "CoreKeyboard"<br><br>
EndSection<br>
#as i said before I will update<br>
#special thanks to the Slax project [<a href="http://www.slax.org/%5D" target="_blank">http://www.slax.org/]</a>
Discussion Starter #2
why haven't you said any thing hobo?
<div>Originally Posted by <strong>General</strong></div>
<div style="font-style:italic;">why haven't you said any thing hobo?</div>
</td>
</tr></table></div>
lol, sorry I've manly been working on my FC6 install for the last few hours and then I just rebooted and no Grub. It was there the first few times though. And restore failed so I'm taking a break now.<br><br>
Looks like a good working xorg.conf file. I'm not sure what you want me to say about it though. Xfree86 is pretty much dead.
Discussion Starter #4
UPDATE<br><br>
added the options for composite and hardware rendering<br>
ATI users plz give me some input
Reactions: dangerousHobo
Discussion Starter #6
some misc updates
<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br>
Just finished getting 3ddesktop and hardware accel on Slamd64 (64bitslack)<br>
Grabbed a couple lines from your first post - many thanks and +R for ya <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #8
added a devices section for nvidia card and a screen section for nvidia<br>
and some twinview info
Discussion Starter #9
bump
^^That's my user name^^
??? This is confusing me??<br><br>
Wait, I just copy the lines I want to use?
Discussion Starter #11
depends, you see the modes line, in the section screen?<br>
those comments, ' "1280x1024" ' are your available resolutions, if you add one then it becomes available
I won't comment# out the Option Emulate3Button. I think if you do then the scroll wheel wont work. At least I found that problem with Slackware.
Discussion Starter #13
<div>Originally Posted by <strong>dangerousHobo</strong> <a href="showthread.php?s=34ef0cf377f7f84bfe5f471f00791160&p=1594589#post1594589"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I won't comment# out the Option Emulate3Button. I think if you do then the scroll wheel wont work. At least I found that problem with Slackware.</div>
</td>
</tr></table></div>
that is really weard, its a option for two button mice, is the "zaxismapping" option in your xorg file?
Ahh the X11...<br><br>
I spent a good two full days messing around with that code to get my Dell Inspiron 1100 working at it's full 1024 x 768 goodness. (with Ubuntu 6.04)
Discussion Starter #15
added how to oc your monitor
Discussion Starter #16
*sigh* maybe this will finnaly get stickyed
1 - 16 of 16 Posts
