1 - 20 of 22 Posts
Originally Posted by mfillpot
What more are you looking for? it is a pretty simple mod to make.
ok and i have one more thing is how can u get clean air go in ur comp? like wut can i use i know a filters but wut are they made of??
If you want to make your own filters, you can use the material from the filters made for the house air conditioners..
I recommend getting premade filters online though, they're cheap as it is...
Linux Guru
I am using ladies nylons for my fan filters, they are thin, bendable, breathable ,cheap and they catch most particles.
Discussion Starter · #8 ·
ok ic now
Linux Guru
Originally Posted by archer_456
LMAO, Does it matter if you use the control top panty hose?
I got the idea from a female co-worker when I described the type a fabric I need, I don't know the differences in pantyhose, I just cut it to use the thinnest part.
I know you pict as me because you care, but trust me, it is better then a thick filter because is restricts the airflow less.
Your right I do care, LOL.
It is a pretty good idea though, I might have to try it out..
Linux Guru
Since I put them on I have to clean them once a week to get rid of the cat hair and dust that would have utherwise gotten into my case.
I get unconfortable in the ladies section of any store, luckily I have a wife and she had a few new pairs that I could steal, I only needed one, but I also had a choice of colors...lol
Just tell everyone you are going to rob a bank.
Originally Posted by overclocking-the-world
I bet that looked attractive buying Ladies pantyhose at the drug store or Where-ever you bought them.
LOL, not as bad a buying tampons, well maybe it is. At least with tampons the store clerks KNOW that you aren't going to use them....
1 - 20 of 22 Posts
