1 - 14 of 14 Posts
First off i want to say that i looked for a Guide or Tute section and i couldnt find one. Navigation on this site leaves a bit to be desired.
NOTE: I assume no responsibility for any harm or breakage due to this tutorial. Making your PSU modular will not make you more popular with the opposite sex. It will not make hair grow on your chest, however failure to follow EXPLICITLY this tutorial can cause hair loss which is not popular with the opposite sex.
Rough (but minimum) list of tools and items needed:
1. PSU (duh)
2. Soldering iron and .032 dia. rosin core solder (Radio Shack has good stuff for this)
3. Screwdriver, usually #2 Phillips
4. Multimeter (just in case)
5. Wire strippers, the blue and yellow ones are available different places and work great for all sizes of wire
6. Side or diagonal wire cutters
7. Heatshrink tubing (HST), you want the matte finish or MIL SPEC kind, the shiny finish stuff sucks (also at the Shack) and electrical tape
8. Heat gun
9. As many jacks and plugs as you be doing dongles for (2 in this case) Also found at Universal Radio
10. Dremel with normal sized sanding drum
11. 1/8" metal or bi-metal drill bit
12. 9/16" boring bit for wood or metal, doesnt matter here as it wont dull enough to be ruined
13. Piece of 1'" x 2" wood, at least 8-10" long
14. Optional, switch for shorting PSU to turn on, LED to show PSU is on (not done in this installment), fans to replace boring stock ones
Sticker of doom! We are doomed! If you are ballsy enough, go ahead and ruin your brand new 5 year warranty and do this mod! Again I assume no responsibility for any harm or breakage due to this tutorial.
5 screws later and the top is off, man im tired...(NObody gets that joke?)
Isolate the wiring you want to modify, untangle and set aside
I opted to place the plugs above the main wiring outlet, due to the dual fan setup I was limited to where i could place jacks. Before i drilled and made a hole i didnt want, i made sure i had at least 1" clearance behind the case panel for the jack and wiring to make sure it wont be pinched or kinked when re-assembled
Lay out your jacks to make sure you have enough panel room and clearance behind the panel for the nuts so the jacks can be tightened properly, dont space them too close together. I left enough room to add another jack in between but off set from these two at a later date
Mark CAREFULLY and drill your holes, i opted to do one at a time due to heat. Patience is needed here as the steel is fairly tough and you dont want fingers or wiring ruined from drilling too fast. Use the 9/16" boring bit and then the dremel to clean up the hole, sanding until the drum fits in the hole and then its the perfect size for the jack. Using the 1" x 2" piece of wood comes in handy here, drill a relief hole (not all the way through) with the boring bit FIRST, then center that hole with the PSU housing and that way you use the wood for holding the flimsy PSU casing still and wont burn your fingers from the heated steel
Now that youve made sure the jack fits good, you want to tin the tips of the wires. Hold the soldering iron and solder to the wire and coat the entire end so the individual wires are now one. This is so youll have an easier time soldering to the plug and later the jack
Gently cut off the heatshrink and ziptie, slide a new piece of HST at least halfway down (farther from the heat source the better till youre done soldering), and then the plug once its disassembled
Carefully solder the plug end on, the pins are numbered 1-4, i used 1 for Yellow, 2 for Red, and 3/4 for black. The jack is also numbered, but in a reverse pattern so the pins will match up when mated.
I noticed on the Molex plugged dongles that the black wires are joined together on the inside, which is why i havent said anything about using the multimeter to verify which black wire you have (via continuity testing), the SATA connectors however do have dedicated black wires which will be addressed in the next installment
Plug Jack
1 | 3 3 | 1
2 | 4 4 | 2
Due to the limitations on the premodded dongle, i used some electrical tape vs HST to isolate the wires from each other and the plug housing
Slide the plug housing up and wriggle the HST till it sits in the housing but also covers the sleeving, shrink it using the heat gun, assemble the plug and admire your work!
For the inside of the PSU, the wires are long enough to use HST on each wire, make sure you cut it long enough to cover the terminal as well as the bare wire. Chances of it ever getting knocked around enough to short out while the PSU is on is VERY slim, but we want to cover our butts (and connections) and do the job right the first time
Sorry for the shaky pic, didnt realize it was fuzzy till now or i would have taken another one
Enjot your newly modded modular PSU!!
I did not replace the fans as the ones inside were 20mm thick and i didnt know that prior to buying the new ones or writing this tute (originally in 2007)
Hey, just like people used to do BITD before companies started making modular PSUs! Nice to see that someone's still doing this even if it was 4 years ago. Of course using a TR2-430 is fail...
Still, good job.
I cant complain, that PSU has been running non-stop since i installed it in 08/2007. But thanks
I'd rather do that to a decent PSU that might make it worth while, but otherwise, good thought with the XLR connectors. They should be able to handle a good amount of current.
Nice work.
Watercooled Railgun
Hm, might try this for my HTPC PSU, i could so get rid of many cables on it.
Discussion Starter · #9 ·
Yea, and the place i linked for the connectors has 5 pin sets for SATA cables
Watercooled Railgun
Actually i'd look for 4-pin jacks, to get rid of Molex cables
Discussion Starter · #12 ·
Bump
Wanted to mention that the PSU I used above has been running non stop since this mod (over 4 years now) and just got transplanted into my parents Gateway to live on.
i dont really get what was gained with this specific mod. it looks like you have the same number of cables before and after. i like the idea though
Discussion Starter · #14 ·
When i did this, it was the geek factor as i really needed that many cables, but this will work great for people who would want to do clean up their PSU. Ive toyed around with making a completely modular PSU, but doing the 24 pin would be cost prohibitive unless you used three 8-pin connectors, but then you couldnt sleeve the wires or even use a decent gauge wire.
Or, you could do it simply for the geek factor
1 - 14 of 14 Posts
