http://www.newegg.com/Product/Produc...-090-_-Product
(first picture in the gallery)
The GentleTyphoon has partly covered the drill hole, as you can see here. So there's no way to mount the fan with the included clips. Does anyone have any tips? Also, which way faces the heatsink, the blank side or the side with words? Thanks
