1 - 9 of 9 Posts
Hi,
watercooling newb here
. I just got a p120.3 radiator but am wondering how I should mount it on the top of the cosmos s? Screws?
The screws for the fans are really weird as well - the normal fan screws (the fat ones) wont fit and the normal computer screws are too small....are there supposed to be screws that come with the rad..?
Thanks in advance
woot
Originally Posted by gnolnats
I just bought one of these rads. I was thinking of mounting it on the rear of the case.
rear of the case works well if you wave a spot for a 120mm fan in the back
the standoffs are just threaded rod with heakshrink over them
Thanks for the replies! But how about mounting the radiator to the top of my case? I've seen many people top mount their triple-rads on a cosmos s...do they just use screws..? And should I go for the fan|rad|fan or just rad|fan setup..?
woot
Originally Posted by mtbhrd
Standoffs? Try stilts! I never seen a rad mounted that far off.
needed room for the t and res. also keeps it out of the way of the cables
1 - 9 of 9 Posts
